楼主: 天雨
錾花用——錾花胶、火漆和砧铁
发表于 2010-10-26 17:25 | 显示全部楼层
6 parts chaser's pitch, 8 parts plaster of Paris or brick dust, 1 part linseed oil or tallow. Source: Metalworking Techniques for Craftsmen by Oppi Untracht.
4 parts roofing tar (the kind roofers melt in tar kettles), 3 parts pumice powder, 1 part turpentine, 1 part linseed oil. Melt tar in pan, stir in turps, add pumice. Let a small amount cool and adjust amount of linseed oil to get desired consistency. Source: My own recipe.
Equal parts of beeswax and plaster of Paris. This is good for very thin, fully annealed non-ferrous metal worked shallowly. Again, my recipe.
When mixing any of the recipes for pitch, remember that some or all of the materials may be flammable and take appropriate precautions with regard to open flame, etc. It's a good idea to keep in mind that hot pitch sticks to you and keeps on burning much longer than is bearable, too.
For steel or relatively thick (greater than 16 ga.) non-ferrous metal, you want the pitch to be stiffer than you would for softer or thinner metals. The stiffer the pitch is, the sharper the detail you can get, because it doesn't distribute the force of the punch as much as softer pitch does. For preliminary bumping of the gross forms, I use a softer pitch, and then switch to a stiffer consistency for detail work or chasing from the front. Sometimes, depending on the nature of the project, the initial bumping can be done over a sand or shotbag, or over a depression in a wood block or stump. If it is important that the perimeter of the piece be very exact, it's sometimes easiest to leave it large and cut it to the final contour after all the repousse'/chasing is done.
先感动自己。。。
发表于 2010-10-26 18:28 | 显示全部楼层
一、胶的配制及胶板、胶球和胶棒等的制作方法 1. 胶的配制及用途 (1 ) 胶的配制胶是一种黏固材料, 在贵金属饰品、工艺摆件加工中,
用于粘固饰品、填充工艺摆件内腔、錾刻花纹以及抬压图形等。目前市场出售的火漆是胶的代用品。胶由碳酸钙粉 ( 复粉或瓦灰) 、石蜡、松香三种主要材料,
按相应比例通过加热混合而成。制作时可将松香放在金属器具中加热, 待松香熔成胶状后放入石蜡, 让石蜡完全熔化再把碳酸钙粉加进去, 然后反复搅拌,
把三种材料完全混合。现通常用植物油取代石蜡, 碳酸钙粉、植物油、松香的配比为 4∶1∶1, 配制方法同上。加热时要不断搅拌, 直至冒泡, 此时温度约为
150℃左右。如果要将胶配上红色, 可在加入碳酸钙粉的时候, 放进少量红色颜料粉一起搅拌。 (2 ) 胶的分类胶分为软胶和硬胶两种。软胶在常温下胶质稍软,
略带塑性; 硬胶在常温下胶质偏硬, 带有脆性。两种胶的配制主要是调配好石蜡或植物油和松香的比例。气温对胶的硬度有一定影响, 各地区应根据当地气候情况,
结合使用要求来调配材料的比例。 (3 ) 软胶的用途软胶常用作立体或半立体工艺摆件錾刻花纹、抬压图形时的填充物料。使用方法是把胶加热熔解, 然后灌入工件内腔,
待胶冷却后进行錾刻、抬压。 (4 ) 硬胶的用途用硬胶配制的胶球或胶板, 通常用来粘固准备錾刻的首饰平面或准备錾刻的饰品表面花 ?? 1 ??
纹。使用方法是用喷枪喷出缓火将胶加热软化, 然后把饰品放在胶的表面粘固, 待胶冷却后即可进行錾刻。 2. 胶球的制作方法 (1 ) 制作胶球方法之一先准备直径为
110~130 mm, 底部为球形的铁碗或不锈钢碗, 然后将配好的胶敲碎, 分批放入碗内, 用喷枪分批进行加热, 待每次放在碗里的碎胶熔成胶液后,
再加入新胶。如此反复操作, 直至把胶添加到合适高度或加到碗口位置为止 ( 一般胶球高度应大于碗口半径) , 待胶冷却后便成胶球。 (2 )
制作胶球方法之二事先选择规格合适的椰子壳, 把多余部分锯去 ( 留下部分的高度应大于半径) , 然后用水泥、小石头 ( 体积约 10 mm×10 mm×10
mm) 、沙子三种材料拌成混凝土放进椰子壳里, 这时注意不要把混凝土放得太满, 要留有放胶的空间。放进椰子壳里的混凝土要用小铁杆反复搅动几遍,
这样做除了对混凝土进行排气外, 同时也加强了混凝土在壳里填充的紧密性, 使混凝土干固后的整体比较坚实, 达到外部比较光滑的效果 ( 但平面位置要专门刻痕,
以加强它的粗糙感) 。待混凝土完全干固, 把碎胶放在混凝土平面上, 然后用喷枪把碎胶熔成胶液状, 铺盖在混凝土上面的胶的厚度大约 8~10 mm
便可。胶冷却后用锤子轻轻地把椰子壳敲破并剥去, 剩下就是一个用混凝土倒制的胶球。这种胶球的外形如图 1—1a 所示。图 1—1 胶球、胶板、胶棒实物图形 a)
胶球 b ) 胶板 c) 胶棒 3. 胶板的制作方法先按尺寸加工好木板。常用木板的规格尺寸为 250 mm×150 mm×30 mm,
也可以根据饰品工件的加工需要选择木板的大小。然后把碎胶放在木板上, 用喷枪对胶进行加热。胶的铺放厚度要根据工件的加工需要来确定。常规使用时, 胶的厚度在
10~15 mm 范围内。用手压平, 待胶冷却后便成胶板。胶板的实物图形如图 1—1b 所示。 4. 胶棒的制作方法胶棒是在各类小型镶嵌饰品 (
如戒指、吊坠等饰物) 的加工中, 进行镶嵌宝石、钻、翠等工艺所使用的一种辅助工具。胶棒的实物图形如图 1—1c
所示。胶棒的制作比较简单。首先选用棒体。胶棒的棒体可选用普通锤子的圆形 ( 或椭圆形) 木柄, 直径约28 mm, 长度110~120 mm
左右。然后把胶放在木棒的截面上, 用喷枪加热, ?? 2 ?? 待胶冷却凝固在木棒上便成为胶棒。
天地为炉兮 万物为铜
日月为炭兮 造化为工
发表于 2010-10-26 18:31 | 显示全部楼层
你手打上去的啊?厉害 23# yyhh
先感动自己。。。
发表于 2010-10-26 18:32 | 显示全部楼层
这书上说是碳酸钙粉、植物油、松香的配比为 4∶1∶1,
我这两天也想配这胶,材料都备齐了,就是松香一时忘了藏哪儿去了,
到时候实践一下,
其实一般的錾花,用火漆也很方便。
慢慢来吧,要学的东西多着呢。
天地为炉兮 万物为铜
日月为炭兮 造化为工
发表于 2010-10-26 18:33 | 显示全部楼层
到时候实践一下,
其实一般的錾花,用火漆也很方便。
慢慢来吧,要学的东西多着呢。
yyhh 发表于 2010-10-26 18:32
这个比例配出来不知道会不会很软
先感动自己。。。
禁止访问
发表于 2010-10-26 18:52 | 显示全部楼层
发表于 2010-10-26 19:03 | 显示全部楼层
油不需要那么多吧,一般我配先化松香,再加白土子,最后放油,油不是一次性放,分多次方,放差不多了,弄少许胶出来浸冷水,然后看硬度合适不合适,硬了再加油。
谢谢,正在想找个顺序呢。  发表于 2012-1-8 15:26
在人类所有一切可以谋生的职业中,最能使人接近自然的职业是手工劳动   http://suhua99.taobao.com/
发表于 2010-10-26 19:17 | 显示全部楼层
free 发表于 2010-10-26 19:03
  好法子
先感动自己。。。
发表于 2010-10-27 13:37 | 显示全部楼层
天雨说加炭黑,
我手头正好有激光打印机的粉
就加了一点进去,
效果很黑,很好
天地为炉兮 万物为铜
日月为炭兮 造化为工
 楼主| 发表于 2010-10-27 17:39 | 显示全部楼层
GMT+8, 2026-10-2 21:26 , Processed in 0.156282 second(s), 30 queries .
